Predator Top Model
someone of you has the predator? it knows to give impressions to me ? excuse for my bad english.
Predator with OS 91fs S II Pump, 3.5 kg |
Predator Top Model
Hi Fonzie,
Building mine at the moment for a Saito 100. Is yours flying? |
Predator
1 Attachment(s)
This is my Predator with OS FS 91 SII PUMP, it is fantastic in flight, weight 3.5 kg, servos; 2 HS 545 BB HItec for aileron, 1 HS 645 BB MG for rudder, 1 Hs 81 for torttle, and 1 HS 545 BB for elevator, 5 cells 1470mah SANYO. I have canged the original undercarriage with a carbon MK KATO, the original is very bad!! CIAO Alfo.
Predator Top Model
Is it plugin og bolt-on wing?
The plane does look marvellous, I've seen it before but the small pics I've seen did definately not do it justice! |
Predator Top Model
I have been thinking about buying one of those as a pattern trainer. How does it perform in pattern type flying?
It sure looks great! |
predator
1 Attachment(s)
It is wonderfull like trainer for pattern, your profile is NACA 64A014,the proportions are like a F3A, 1.67m x 1.60 m, for me the bst engine for predator is YS 91, because OS FS 91 it is not much powerful one. CIAO ALFO.
Predator Top Model
Hmm, how much is it? Is there a website for it?
Predator Top Model
Ciao Fonzie,
Sorry guys for the Italian reply, I will translate. Fantastico. Ho visto la prova su una rivista francese. Sembra proprio un bel modello. Dove voli? Io volo dalle parte di Brescia. Complimenti per il tuo modello. Ciao. |
Predator Top Model
http://www.espritmodel.com/
They advertise here. I bought mine through these folks and they were very helpful. Question for other builders- This is my first time with a metal wing-tube. Should the tube be permanently attached to the fuselage or left loose in the fibre-glass guide tubes? |
Predator Top Model
If any scandinavians are reading this, El flight in Denmark carries it at a reasonable price:
http://www.el-fly.dk/predat-1.htm (Some pics there too, for those who don't speak Danish :) ) |
Predator Top Model
Rossan,
I don't know about how they built the wing tube on that kit but I HAD a japanese kit from Dash 45 which had a lose tube in the fuse and it work great. Up to you. |
| All times are GMT -8. The time now is 03:50 AM. |
