3 Bladed Prop for 3D
Would there be any advantages of using a 3 bladed prop for 3D flying? You'd think for hanging on the prop it would be better since there is more prop area.
RE: 3 Bladed Prop for 3D
I think the only advantage is better down line breaking than with a 2 blade. Overall 3 blade props are not nearly as efficient than a 2 blade, but they look cool and if you have the power to spare go for it.
Just curious did you get the problem with the evo figured out? |
depends on the engine..... anything under...about a 50cc engine.... the 3 blade prop is far too inefficient....
some use them on sport/trainer planes, or on a scale application, but they are very inefficient for 3D... what engine? |
I'm still working on it. Dick Hanson had mentioned in an earlier thread that the 24x10 might be too much for the engine here at 5000 ft. So, I ordered a smaller prop today. I wanted to get a Mejzlik 24x8, but they don't make one so I got a 23x10. Another guy started using a 24x10 on his and only got 6200 RPM so i'm also thinking the altitude may play a big role. I replumbed the tank in case the problem was arising there. I doubt my new prop will be here by this weekend so I can see what the current improvements are. I know some people may disagree with the prop decision, but right now I think it's something i'm going to end up trying in the end.
quieter set up on cans downline braking is better on a 2 blade of the same pitch
What is best for downline braking? Large diameter or large pitch?
1 Attachment(s)
HI i run a 3 blade on my mvvs 58 22x12x3 & its the ultimate combo.3D& IMAC are insane.
its a great set up as i have had my props on this motor.LOOKS ARE A ADDED BONOUS cheers glen |
what muffler do you have on that engine?
large diameter with a low pitch will provide outstanding braking.....
So a 23x8 will be more efficient at braking than a 22x10?
How about an 3x21x10 in a theoretic comparison? As it is, these are the choices that I consider for my Evolution 45GX (equal to DA50 in power), but can't quite decide. Will use for 3D and precision, with bias towards precision. |
23x8 would be better at braking than a 22x10. I can't say about the other prop. The reason why I bought a 23x10 is that the 24x10 seems to be too big and Mejzlik doesn't make a 24x8. I'm not trying to stay with them because of the name, but rather that I have a carbon fiber spinner and I don't want to adjust the slots myself.
| All times are GMT -8. The time now is 07:33 PM. |
