how to spend $400?
If you had $400 to spend on a .46 size 3d plane and engine, what would you buy?
RE: how to spend $400?
Easy MOJO 40
OS 46 AX with a MACS pipe or Webra 50 |
ORIGINAL: lomcevek1 Easy MOJO 40 OS 46 AX with a MACS pipe or Webra 50 |
Does the mojo come as a kit only. I'm restricted by time, space to build right now.
I'm in the same market & am looking at the OMP Katana V2 46 ARF.
I'm going with Saito 72 so I'll be a bit over 400. :D |
Why don't you get the combo with the YS 63? A way better engine for $384 including shipping. I also have my eye on this deal. I am also looking at the Badboy. The Mojo arf appears to have a wait.
ORIGINAL: walleyevision Why don't you get the combo with the YS 63? A way better engine for $384 including shipping. I also have my eye on this deal. I am also looking at the Badboy. The Mojo arf appears to have a wait. |
IMO, the Saito 72 doesn't compare to the ys 63. If you must go Saito, you should get the 82. It's the same size. The 72 is really kind of outdated.
ORIGINAL: walleyevision IMO, the Saito 72 doesn't compare to the ys 63. If you must go Saito, you should get the 82. It's the same size. The 72 is really kind of outdated. Can you say foamy power! |
My experience with Saito 82 on a profile hasn't been very positive. While it's a great engine, it does have a lot a vibration. As for the profile, a vibrant nose result in a very dynamic fuel tank. I can see the fuel getting twirl around like juice in a blender. It will cause much leaner mixture as fuel is getting consumed, so I end up starting the flight w/ very rich idle setting.
I don't have this problem on a fatty. Profile just seems to have this problem with Saito 82. Hey, look out for the new Webra 55, due out in US mid May. 13x4W @ over 12k rpm, baby! |
I have the first version of the Katana gs 40 with a saito 82 on it. With a 14 x 6 master airscrew prop this thing hovers at 1/3 throttle and rockets out of a hover!
ORIGINAL: seanychen My experience with Saito 82 on a profile hasn't been very positive. While it's a great engine, it does have a lot a vibration. As for the profile, a vibrant nose result in a very dynamic fuel tank. I can see the fuel getting twirl around like juice in a blender. It will cause much leaner mixture as fuel is getting consumed, so I end up starting the flight w/ very rich idle setting. The 82 has had more fuel through it so maybe (fingers crossed) the 100 will settle down a but after a few gallons. |
| All times are GMT -8. The time now is 08:42 PM. |
