Prop Selection---H9 CAP/Moki 1.8
Can anybody suggest best prop (brand and size) for Moki 1.8 in Hangar 9 Cap 232, approx 13 lb. I'm looking for best vertical performance, don't care about speed.
Thanks Bob G |
Prop Selection
I have a hangar 9 Edge 540 currently using an OS 1.60FX running 15% Powermaster, spining JZinger 18X8 props. Hovers just above 1/2 throttle, and will climb unrestricted at full power. Max TACH'd rpm ts 7550.
12 bls on the weight, by the way...
the best prop i found on a moki 1.8 is the bolly 19x8. this prop should give any 12-14 lb plane unlimited vertical . the prop is a great hovering prop too as for the speed it is called throttle management. :D
Chad |
Chad is about right, may even try a 20-8. The Moki should have no problem with it. A 20-8 has great 3D on my H9 Edge.
Originally posted by h82crash Chad is about right, may even try a 20-8. The Moki should have no problem with it. A 20-8 has great 3D on my H9 Edge. Chad |
| All times are GMT -8. The time now is 04:45 PM. |
