RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Wide Blade Props (https://www.rcuniverse.com/forum/3d-flying-82/4868035-wide-blade-props.html)
JC 10-14-2006 07:13 PM
Wide Blade Props
Gents,
What is the advantage if any, of using a wide blade prop (APC 14x4W) versus a standard prop (APC 14x4) ?
JC
YNOT 10-14-2006 07:19 PM
RE: Wide Blade Props
For the slow RPM we want in 3D, the wide blade props perform better. They work better in the lower range, the thinner props work better in the high range.
Ian.W 10-15-2006 01:12 PM
i dont like them they spool up slower. then again i have faster spinning props, IMO better for 3D as it gives more responce. saying that on my latest plane 5000rpm is fast!
raideron 10-15-2006 01:51 PM
I like the "W" blades... Seems to be better for me with my type flying(trying 3D)
plus they slow you better on landings.... But I like the normal pitch props when
I'm tumbling around:D
