edge
1 Attachment(s)
Here is mine still under construction I have scratched the whole thing need help on how to make a cowling!!!!
Dteails,
How big,
Engine, Weight, Wing area? |
edge
It has a 84" wing span and it is at 4lbs 7oz so far without the landing gear or radio gear.I am going to power it with a BME 50.I hope to keep it total to about 13-14lb range.
edge
If you want to scratch build the cowl http://www.rc-tech.net/cowl/cowl.html
you can also call stans fiberglass or the others and see if they have a cowl that is close. you might try aeroworks, there 29% edge may be very close to yours. |
edge
You might try D&L Designs they have some large Edge cowls that might work.
http://www.dldesigns.net/ DEG |
| All times are GMT -8. The time now is 06:39 AM. |
