RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   learning to hover (https://www.rcuniverse.com/forum/3d-flying-82/651129-learning-hover.html)
chrisdodge65 03-26-2003 11:55 PM
learning to hover
I have a H-9 Ultra Stik 40 that I plan on useing an OS 46SF.I want to learn how to hover.I this a good engine,plane combo for this manouver?And what size prop will work great?And please any help on how to hover will be much appreciated.I plan on teaching myself.
rc-sport 03-27-2003 03:24 AM
learning to hover
You don't have enough power with that engine. A friend has that plane with a 46 and it looses speed in a vertical climb.
George E. 03-27-2003 12:33 PM
learning to hover
I don't have an Ultra Stick but from the looks of it, it won't be a good hovering trainer.
There are so many good hovering ARF's
The .46 would be great on a Magic. or try any morris plane, goldberg extreme, etc etc etc.
Spaceman Spiff 03-27-2003 07:35 PM
learning to hover
Even with a bigger engine the ultra isn't the most suitable plane to learn hovering on. (that isn't to say that it won't do it) it needs more elevator so it is easyer to pull the tail back under the plane after it starts to fall out. I'm in the process of modifying mine by making a new stab/elevator for it that is similar to the one used on the UCD. A couple guys here on RCU have done that and like it.
rplumbo 03-27-2003 08:02 PM
learning to hover
A friend at the field has the ultra stick 40 with a 46FX on it, and it won't pull out of a hover. Stability seems ok, but it just doesn't have the power you need. If it's around 5.5-6 pounds a YS .63 will hover it. It's possible to hover pretty much everything provided it has enough power. Wait until you see a 1/3 scale stearman hovering, you'll believe it. :)
Reid
Edgeomatic 03-27-2003 09:29 PM
learning to hover
Spend the money for a carden with a DA or a hanger 9
alex24 03-28-2003 04:17 PM
learning to hover
wow, I think there is a big difference in price between a Carden and a ultra stick..... continue practicing CHRIS....
garygee 03-30-2003 03:23 PM
learning to hover
hey chris - im also in the learning stages of hovering im using a pizzas with a os 70 in it and it works great .it pulls out of hover thats the key, having enough power to pull out. keep practing you might have to invest in some new equipment
astrohog 03-30-2003 04:07 PM
learning to hover
hey Garygee, I NEED to see pictures of a hovering "pizzas"! I mean, there are a couple of guys at the field that fly PBF's (pizza box flyers) but I have never heard of an actual pizza hovering!!!:D :D :D :D :D sorry, I couldn't help myself!!!!
regards,
Astrohog
stdun 03-30-2003 09:45 PM
learning to hover
My son has a Pizazz with an os61fx that does whatever he asks of it. I replaced the os46fx on my Goldberg 3D with a os61fx and it made all the difference. Can you really have too much power?
BotleRocketWar 03-30-2003 10:31 PM
learning to hover
"A friend has that plane with a 46 and it looses speed in a vertical climb."
What airplane won't?
The Ultrastick may not be the best for learning, but it will do it. There is no reason not to give it a try...
Try an 11x4 or an 11.5x4 APC...Keep the airplane as light as you can and it should hover. I've never seen one with a .46 that wouldn't...Give it a try! Max out your elevator and rudder throws and go wring it out.
Take a look at the G2 thread and all the others around here and you will get some great tips on learning to hover.
If you want the best for learning to hover, it shouldn't take you more than a couple minutes in this forum to find it! Doesn't mean you shouldn't use what you've got.
Don't listen to the guys that tell you you need a $800 airplane to start learning.
Good luck! :)
Spaceman Spiff 03-31-2003 12:41 AM
learning to hover
Originally posted by BotleRocketWar
"... it looses speed in a vertical climb."
Mine! :D
Rocket is right, no need to spend big bucks, its all in getting enough control throw, prop selection, keep the CG as far back as you can... setup is important. the rest comes with practice.
garygee 04-06-2003 12:34 AM
learning to hover
sorry astrohog ....................................pizazz (you couldn't figure it out ?)
