RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Help!! (https://www.rcuniverse.com/forum/3d-flying-82/682119-help.html)
Rather B Flying 04-09-2003 04:22 AM
Help!!
I have a hangar 9 sport cap 232 .40 with a saito 100. I want to get into 3d but not sure how. I'm using a 13X8 prop and i have unlimited vertical but i thought i would have had better acceleration upline. The plane is pretty quick so what prop should i move up to to trade speed for acceleration. I tried a 14X10 but it seemed like the engine was trying too hard. Also do I need to be tail heavy to be more aerobatic? I'm slightly nose heavy right now. Would that be the reason I cant throw the plane around like I want to? She snaps real quick but I want to be able to do that thing where it looks like the airplane is tumbling head over tail. Kinda like a zero-radius loop. What is that called anyway! Thanks guys! :confused:
JB Rekit 04-09-2003 05:55 AM
Help!!
That is a waterfall, but you need a combination of thing to being able to do 3D. Power, weight, CG, and control sufrace size and throw.
If you are not satisfied with your uplines right now with a Saito 1.00 on a .40 sized airplane, there is a good chance, in fact I know that plane is too heavy to do 3D with (unless you call prop hanging 3D b/c any plane with enough power can theoretically do that. Whether of not the pilot can is a different story). Larger airplanes can make up for this due to the added stability of being larger (but thats a whole new can of worms, everything increases exponentially ect. ex. if wingspan doubles, wing area is going to increase maybe 10 times.)
I have a .40 sized extra with a saito .91 14x8 apc that went on a serious diet to try to make it more 3D capable and after gutting .75 lbs all it will do is a blender and just hover. Too unstable due to a elevator or harrier or anything else. That damn 58" plane has a faster stall speed than my 105" Edge. It also has more wing loading too.
I'm not saying it can't be done, but to get the stabilty to do the 3D manuevers 5- 10' off the deck that plane is going to have to undergo some serious changes.
Don't know how much this helped b/c it has been a long day and I am getting a little delirious.
Welsh3D 04-09-2003 09:02 PM
Help!!
No, it may be a lomcevak .... Waterfall starts and finishes as a tumble, lomcevakj starts with loads of speed and then goes into a power stall type thing ..... to do a lomcevak you need to fly a 45 degree upline and pile both sticks into the top right hand (or left hand ) corners... it should do a few tumbnles before youll need to centralise the sticks, or if you do it high enough, it will go into a knife edge spin by keeping the sticks inthe corners.
You might find my site of interest.... www.3drc.info , also my other site at www.aeroforce.co.uk may be of interest!
Rather B Flying 04-16-2003 07:06 PM
Help!!
thanks alot!
mancha 04-17-2003 03:28 AM
Help!!
If what you want is to trade speed for trust!! try 14X6!!
CrAzYfLyEr-RCU 04-18-2003 01:37 AM
Help!!
I had a 15x8 pro zinger on my saito 100/ultra stick60 combo and vertical acceleration was awesome....just something to think about
Rather B Flying 04-21-2003 01:51 PM
Help!!
With a 15x8 the lowest idle I can acheive is one that will still pull the airplane at least 5 knots. Hmmm, what do I do? I fly off pavement so I always have to dead stick her.
outssider 04-21-2003 03:23 PM
Help!!
try apc 15/4W or 16/4W
