RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Madness C Of G Madness!!!! (https://www.rcuniverse.com/forum/3d-flying-82/704819-madness-c-g-madness.html)
miker652 04-18-2003 03:31 PM
Hi all
I'm just setting up my Madness and in the single sheet of instructions it gives the C of G as 200mm back from the leading edge. From what i've read most have it 37 to 38 percent and I work 200mm as being about 42 percent has anyone else tried it this far back.
TIA
Regards
Mike
YNOT 04-19-2003 03:13 PM
I can't tell you where my CG is on either my Flip or Madness, I don't measure that stuff. I fly the plane, and make adjustments until it flys the way I want it to fly. Here is hint, most all my planes, I need to push down elevator to land them, thats how far back the CG is. Most people pick up my planes and are amazed how far back it is.
robert 04-19-2003 03:42 PM
see the review under articles at www.rcaerosport.com
One of the reviewers has a CoG point there.
mikey-3d 04-20-2003 08:31 PM
hi miker
i fly my madness at 180mm wich i find perfect for this set up,it will spin flat on rudder with only slight aileron correction.
good luck.
