props for 3d
To set up for 3d and hovering have found the so called hover props
a bit so so been able to get better hovers on 6 inch pitch pluss was just dropping out of a hover so i went a smaller prop more pitch so the static thrust was lower but but a higher speed thrust over controls and now can hold hovers have found this on 46 to 120 planes has enyone else found this so what is your best set up |
RE: props for 3d
a 15x4 w blade was great
but a 14x6 was beter for a hover 14x4 was just to far so a 14x5 is my pic on a asp 91 powered modeltech excite for a 46 powered badboy 11 the 12.25x3.75 was so so the 12x4 apc was great |
RE: props for 3d
I've had some mixed results. The 15x6 I used to break my O.S. 91 4 stroke in with, seems to make more static thrust than the 15x4 I got to fly with. I'm gonna try both in the air and see what happens.
| All times are GMT -8. The time now is 11:44 AM. |
