RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   tru turn spinner problem (https://www.rcuniverse.com/forum/3d-flying-82/7560729-tru-turn-spinner-problem.html)
walleyevision 05-30-2008 05:24 PM
I bought a 3" tru turn spinner and a tru turn four stroke double jam nut adapter for my ys 110. The problem is that the screw which holds the cone into the backplate will not make up enough to bring it tight. Can I solve this with an extra washer?
StPeteFlyer 05-30-2008 05:39 PM
RE: tru turn spinner problem
I would just shorten the screw. That is what I had to do on mine.
Flying freak 05-30-2008 08:36 PM
As StPeteFlyer said i just shortened the screw, dremel cut off wheel did a nice job of it...
Steven
3D_Junkie 05-30-2008 10:56 PM
If you don't want to cut the screw (which is what I would do). You can buy a shorter 10-32 stainless socket head cap screw at the Hardware store.
walleyevision 05-30-2008 11:27 PM
Now why didn't I think of that, Junkie? Thanks
kid chuckles 05-31-2008 03:47 PM
Man if you have a dremmel just cut about a 1/4" off the screw you have. Just about all of them have to be shortened to tighten up.
