RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   need to choose plane for a da 200 (https://www.rcuniverse.com/forum/3d-flying-82/8595322-need-choose-plane-da-200-a.html)
paulhelis 03-19-2009 06:21 PM
hi
i just recived the news that im about to recive my DA 200 engine
i have been a little out of props because i went in to jets
so im a little out of date , i need a recommendation on wich plane will be good to install the DA 200
i already have a hangar9 ultimate with a quadra 200 and a 3w votec 232 with a 3w 150
are this ok?
or there is some new planes that i can chose that suits better for the DA 200?
please give me some advice
thanks and sorry for the bad english
MetallicaJunkie 03-19-2009 07:01 PM
RE: need to choose plane for a da 200
this might work http://aero-works.net/store/detail.aspx?ID=279
Rick75 03-19-2009 07:28 PM
How about this one!
http://www.composite-arf.com.hk/ar/Product?357000
nitro wing 03-19-2009 09:58 PM
http://www.probuild-uk.co.uk/content.php?id=44
nitro wing 03-19-2009 10:03 PM
http://www.probuild-uk.co.uk/content.php?id=47
paulhelis 03-20-2009 01:54 AM
wow !!!
its a hard decision, i liked the composite arf yak and the aeroworks extra 260 because i already have a bipe
thanks
is there a phyton available?
victorzamora 03-20-2009 10:09 AM
How about [link=http://www.chiefaircraft.com/rcmsec/Models/PowerAirplanes/AviationModel/Pitts40.html]this one[/link]? I think it's a Python. If not, it's close enough :D
victorzamora 03-20-2009 11:08 AM
After a bit of research, I still have no idea if they're the same plane or not.
Edit: Just found it, the Pitts Model 12 IS the Python!
paulhelis 03-20-2009 12:30 PM
victor that pitts its georgeous
esta fregon
KWJ48 03-20-2009 03:44 PM
Just another suggestion [link=http://www.qqaircraft.com/planes.asp?s_nav=2&s_ID=11801&s_PART_CAT=b&s_PLANE _CAT=g]QuiQue Yak[/link] They also have a python but it's 100cc.
sevans16 03-21-2009 12:15 PM
Comp-Arf or maybe the new AW Ultimate?? I am not sure on the weight and balance with the AW Ult but if you like biplanes that is the hottest biplane out!!
The new Thunder Tiger TOC Pitts is a monster plane that should take the 200 very well!! I just picked up a TT TOC 40% Yak. I am putting a 3W 210(2cyl) on it. The only planes I really found to handle the weight were the TT TOC Yak, Pitts; Comp-Arf 3.3m. My 210 weighs about 2lbs more than a 150-170. I am not sure what the weight is of the 200(4cyl).
3W makes a 4cyl 220cc, you might do a search on it and see what guys are putting it in??
nmking09 03-23-2009 09:14 PM
Aero-works 42%yak but the best would be....
Carden 126" Extra 300 mid wing, seen two setup with that engine, perfect!!
highfly24 03-25-2009 08:27 AM
Here is a good one i found. Hope you like it. It is big and this is just the right size for that engine I think.
http://www.aircraftinternational.com...4cap232_p1.htm
Ricardo M. 03-25-2009 01:47 PM
1 Attachment(s)
CA Model Edge 540 45% CPLR Design
www.camodel.com.ar
3W flyer 03-28-2009 05:55 PM
i vote for the aero-works 150cc yak 54 also.
LuisCastillo 03-30-2009 07:59 PM
Paul! Don't go so far, ask Mr Sierraplane! jajajaja:D
TorkRollN 03-30-2009 11:26 PM
Well, My vote is to put the DA-200 in a Composite-ARF 3.3 meter Yak 55SP.
But, I'm putting my DA-200 in a 50% Bill Hempel Cub for the 2009 Joe Nall for now !
Barry
