RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   THROTTLE SERVO SPEED (https://www.rcuniverse.com/forum/3d-flying-82/8718287-throttle-servo-speed.html)
ro347 04-27-2009 12:22 AM
WHAT WOULD BE THE OPTIMAL SPEED FOR A THROTTLE SERVO ON A 4 STOKE ENGINE? IM SURE TOO FAST RESULTS IN A DEAD STICK, HOWEVER, WOULD BETTER THAN .21 SECS HAVE ANY IMPROVEMENT IN RESPONSE?
nitro wing 04-27-2009 12:45 AM
RE: THROTTLE SERVO SPEED
I just use standard servos on 4 strokes for maaany years.Properly tuned they respond,perfectly to the servo.Not sure if the engine could spool up and down much quicker.Maybe a YS is quicker than a standard servo.Really depends on how you fly :)
ro347 04-27-2009 12:59 AM
I was just curious. I make certain that my engines are very well adjusted. I take it very seriously as I fly over a pond. As I was breaking another engine in today I noticed the normal lag of fractions of a second when jumping from idle to mid/full throttle, and was just curious.
Jezmo 04-27-2009 01:07 PM
I've got a Hitec HS6975HB running the throttle on a Saito 91 and it doesn't dead stick. I am running a five cell pack and I think at 6 volts the 75HB is listed at .10 . Before you ask it is a spare I already had so I used it instead of buying a new servo. It and the Saito are on an AeroWorks Extra 260 QB and yes I do feel the faster servo helps with throttle response which to me matters when doing things like hovering.
ro347 04-27-2009 03:08 PM
Thanks Jezmo. I wasnt sure if a digi servo would be too fast for throttle. I will give it a shot and see how I feel about it. Thanks again.
victorzamora 04-27-2009 04:16 PM
I've got a servo rated at .09s and it's a lot of fun to have a servo quicker than your engine's response.
Jezmo 04-28-2009 11:32 AM
Yeh Vic, I agree, it makes you feel more comfortable doing the close to the ground stuff. The thumb seems to be more in control of whats going on with power and when my tail is fixing to touch the ground in a hover it just adds confidence. Have a good one man.
ro347 04-28-2009 12:30 PM
Exactly what im looking for. That quick response without too much lag - obviously with a properly tuned engine.
Do you guys have any suggestions on servo - I am looking for something around .10 range that isnt too pricey. Futaba doesnt really seem to have anything and Most of the hitecs are mini servos.
exeter_acres 04-28-2009 12:45 PM
I use HS-81's on 6v for glow throttles.
rated at .09... works fine for me.
ro347 04-28-2009 12:58 PM
Thanks guys! I can always count on this forum.
ro347 04-28-2009 01:33 PM
So ive decided to give the Hitec HS-82MG a shot at .10sec. Do you think I will need to re-tune since im using a much faster servo? I broke in and tuned the engine in using a .19 sec servo.
mrbigg 04-28-2009 05:11 PM
ORIGINAL: ro347
You have to tune the engine every day you fly.
ro347 04-28-2009 05:21 PM
This is true with 2 stroke, but doesnt seem to be the case for 4 stroke.
