RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   U-CAN-DO-3D *46 SIZE WITH A.61 EVOLUTION? (https://www.rcuniverse.com/forum/3d-flying-82/9738649-u-can-do-3d-%2A46-size-61-evolution.html)
costarican_pilot 05-16-2010 11:39 PM
My friend is selling his u-can-do 3D 46 size but i sold all my small engines i swicht to gasonile the smalest i have is a 61 evolution and i was wondering what do u guys think this plane with a 61? im looking for 3D so ofcure i will need to move the batterie back but just in general what do you guys think>? check this video out the guy is flying with a 61 super tiger wich is heavier than the evolution ! thank you http://www.youtube.com/watch?v=-wXDutTX_RQ
asmund 05-17-2010 03:57 AM
RE: U-CAN-DO-3D *46 SIZE WITH A.61 EVOLUTION?
Thay should work out fine, a 40 size engine will be to small for real 3-D anyway. I am going to use a .91 fs in mine when I get to assemble it.
costarican_pilot 05-17-2010 10:28 AM
.91 for a 56 wingspan plane i beilive is an over kill!
rightflyer 05-18-2010 07:45 PM
It will rock as long as the 61 is used for power and not speed.
costarican_pilot 05-18-2010 10:22 PM
haha thank you awsome! :) and what happen if i renforced the plane for speed with the 61? where can i renforced the wings and how?
MetallicaJunkie 05-18-2010 11:17 PM
you would need some good servos and 4-40 ball linkages to eliminate possible flutter....
rightflyer 05-19-2010 09:26 PM
Flutter is the issue. You can use good servos ,seal your hinge line, but the best thing you can do is only use full throttle on vertical up lines and not in level flight or down lines
costarican_pilot 05-21-2010 10:28 AM
go it thank you :)
ES CONTROL 05-21-2010 05:31 PM
A long 4 pitch prop will keep you safe in power dives.
rightflyer 05-21-2010 05:40 PM
Yep, low pitch helps. Maybe a an APC 14x4
costarican_pilot 05-23-2010 09:59 AM
14x4 is the way to go thank you guys
