I was reading the online manual and it says to use hinge points..are the holes pre-drilled? Is it ok to use Blenderm tape on the top and bottom of the hinge line?
Ok, they both come with hinge points in the kit so you dont need to worry about that, plus the center layer is laser cut with slots for the hinges to go into, the airplane just plugs together
