RE: E-FLIGHT BLADE CP
I want to see if anyone can give me any input on what to do...
I just go through tearing my whole Blade Cp apart to replace a bent main shaft. I was very careful on putting everything together exactly the way it was. I thought I did a perfect job and I followed the guide on bladecprepair.com.
I went to fire her up and she spins up perfect with very little wobble (still havent tracked the blades yet) All my servos are working fine. The problem is when I push the stick or give any input on the right stick it used to jump the way i push right away. Now I have to push all the way to one side and then it barely drifts to that direction. I re-checked everything and it looks ok. When I push those directions without the blades spinning the servos seem to be working fine.
Any suggestions?
Also It takes almost full throttle to lift it off the ground...
