RCU Forums - View Single Post - clueless about upgrades
Old 03-06-2006 | 10:51 PM
Super_Dave's Avatar
Super_Dave
Default RE: clueless about upgrades
First I'd check the ride hight set screws in the suspension arms. If you look down at the suspension arms very close to the diff case you'll see a little set screw in there. If you screw that in it will limit how far your suspension will come up. Its a simple check that only takes a second so I'd do it first and then start messing with your preload like KX sujested.
