RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-06-2006 | 11:49 PM
  #2472
imdjenk's Avatar
imdjenk
Default RE: E-FLIGHT BLADE CP
Great thread guys. I'm on page 36 and my eyes are bleeding! I just got my BCP and was doing a control test, and at full throttle I only get 5 deg pitch unless I put the throttle trim up all the way. Is that normal or should I adjust the linkage so I get full pitch with no throttle trim?
Also I crashed and the paddle blades pivoted and lost their original setting. Any suggestions on the proper angle to set them at? Finally, if I get the aerobatic kit will it make simple hovering easier? Thanks for any help guys, hopefully in a couple of days I will finally be comfortable enough to go higher than 3ft and hover for more than 10 seconds at a time! As soon as the tail spins around more than 90 degrees my brain farts so I have to set her back down.
