RCU Forums - View Single Post - 3w 106 initial test run and observations cont.
Old 03-07-2006 | 08:39 AM
JPrc
My Feedback: (22)
Default RE: 3w 106 initial test run and observations cont.
I would leave the low end set where it has good transition on the ground and gradually lean the top end. From my experience this is how I cleaned up the transition. Most people try to lean the low end and it is really the high end that is to rich. Just slowly creep in on the high and you should see the transition problem go away.
