RCU Forums - View Single Post - Sig Somethin' Extra Build Thread
Old 03-07-2006 | 04:25 PM
Balsa Master's Avatar
Balsa Master
Default RE: Sig Somethin' Extra Build Thread
ORIGINAL: David Cutler
(fourtunatly wit hthe SE the wing is 100% symetcical and wont matter... but it will on most planes)
No it isn't! Don't tell him that!!
The peg that stops the wing from revolving isn't exactly in the middle of the section so it makes a difference which way round the inner most rib is installed.
Apart from that, yes, it's easy to build!
-David C.
is it really?? wow i missed that in the plans,ignore me :-p
CA also doesent soak in the way wood glue does because of its fast cure rate, making it weaker.
