RCU Forums - View Single Post - Help a noob out with Matrix?
Old 03-07-2006 | 06:53 PM
badSN95
Default RE: Help a noob out with Matrix?
The reason you don't want to use the seated measurement for the low end needle is. The seated distance changes when the idle setting is changed. If the idle is set higher the needle is further away from the seat. This is my opinion.
