RCU Forums - View Single Post - need an explication
Old 03-07-2006 | 08:24 PM
B.L.E.'s Avatar
B.L.E.
Default RE: need an explication
In addition to lubricating the engine, the oil also helps seal the piston. In ringless engines, the capillary oil film between the piston and cylinder provides the compression seal. You can sometimes milk a little more life out of a tired old engine that has seen its better days by using an extra high oil fuel. The extra oil seems to help the engine seal the compression better.
