RE: pull - pull system
Need Help!!!! Have .46 cap 580 w/saito .82,skywriter smoke pump and getting ready to change rudder setup from push rods to a Du-Bro 4-40 pull-pull system. I have two quest. @ this time. First,can the servo be offset? By this I mean off center. Secondly, I read you can use reg. horns as long as
the width is the same as the servo control. I do not like this idea because it defeats my purpose,I feel the horn system on this plane is its weak point. What suggestions are out there
