RE: dual elev. setup on JR 9X
yes same -
First go to device select screen --- then
inh the aux 2 switch
then on wing screen- select the aux 2 servo --the two are then coupled - el/aux2 - and trim is active
also ----on mine for some reason the two servos are perfectly aligned in mirror fashion- that is --th servo arms are aligned
On my 10 x when doing this -- the servos are matched but the arm on one servo is 1/2 spline out
Iwish--- JR and everybody -- put a 1/2 spline total adj screw on servo output - just enough to do a perfect match on mirror image or paired servos - It would be sooo simple.
