Interference from ignition?
Hi all,
I have a ryobi 31 on ch ignition.
the battery for the ignition, switch, and ignition box itself is mounted right behind the firewall.
When the ignition is turned on, and the sensor passes over the pickup, my ailerons etc spaz out.
The only other thing right behind the firewall is the throttle servo. Everything else elsctronic is over 12 inches away from all this stuff, behind the wing (Fourstar 120).
My question is, do I need to move the throttle servo back 12 inches away? I thought I had other gassers where this servo was right up there with the motor...?
I just want advice before I go moving the servo needlessly.
Also, what is the number for the resistor plug for the Ryobi 31?
thanks!
Bill
