Installing pushrod guides in Tiger 2 Kit
I've just completed my first kit build and have a question about the pushrod installation. I glued the pushrod guides into the exit slots as per instructions, but am wondering if they should also be attached to the fuse somewhere near the servos to minimize flex. Right now the pushrods flex a bit at maximum travel for the elevator and rudder, and I could see this becoming a potential problem. I've flown the plane 10 or 12 times, so I know it works as is, but I'd rather fix it before it crashes due to pushrod flex. Thanks for the help! Also for any first time kit builders out there I highly recommend this kit. I am by no means a building whiz and this plane went together very nicely, and flys extremely well!
