RCU Forums - View Single Post - Interference from ignition?
Old 03-08-2006 | 08:30 PM
Prop Nut's Avatar
Prop Nut
Default RE: Interference from ignition?
Do you have a rod connecting your servo to the carb? This often is a cause of radio interferance. I use Gold-N-Rod to connect the servo to the carb. Try this before moving your servo. I often mount my throttle servo behind the firewall to move weight forward.
