RCU Forums - View Single Post - Official T-rex 450 XL SE Thread
Old 03-08-2006 | 10:39 PM
  #222
chris b's Avatar
chris b
Default RE: Official T-rex 450 XL SE Thread
ORIGINAL: smadadet
ORIGINAL: chris b
ORIGINAL: ptgarcia
What modifications need to be made to the HS-56 servos to fit the carbon frame? I need to pick up some cyclic servos this weekend and it going to be the HS-56's or HS-65's. Thanks.
Hey ptgarcia, I am not familiar with the HS 65 servo, however the only mod needed for the HS 56 was to cut off the vertical mounts and the mounting on the underside of the servo. Also to make life easy, align and pre drill the holes you need to accommodate for how you are going to mount it before you put the frame together. It is a pain to do it after the frame is assembled. I cut up and sanded an old control horn to achieve the correct spacing for the aileron and elevator servos in the frame. I went with the HS 56's because there was no slop at all; the servo was tight and has been a great performer so far.
An alternate method that I used was to both cut away the vertical mounts as you suggested, but to also cut a slot in the center of the remaining mounts and use a large washer with the screws when mounting it into the existing frame holes. Neither choice is very elegant, but I would rather cut up a servo than take the chance on damaging the frame by cutting new holes.
Just to clarify, when drilling holes for mounting, I am referring to the servo tab (see pic), not the frame. As smadadet says, " would rather cut up a servo than take the chance on damaging the frame" I COMPLETELY agree!!
