RE: MST-1
All you have to do is search this site search "mst-1" and my user name and you'll find a lot of great stuff posted on the truck
My complete MST-1 set up is currently for sale in the market place
Chad bradley's set up
#89 of 1350 by CHAD BRADLEY (chadb) on Tue Feb 3 10:56:48 2004:
04 Hemet Nitro Challenge set up
Front...
Oil............200wt mugen
piston.........1.5
spring.........silver cut 1 coil
shock travel...full + loosen shock end 2x's
shock pos......middle on arm, middle on tower
toe in/out.....0
ride hight.....arms level
camber.........-1
camber pos.....inner hole on bulk head and 1mm washer under
Rear...
oil............350 durring the day, 300 at night
piston.........1.6
spring.........grey
shock travel...full + loosen shock end 2.5x's
ride hight.....arm slightly above level
shock pos......inner hole on arm, outer hole on tower
toe in.........4 on inside, 1 degree hub
camber.........-.5 (neg 1/2)
camber pos.....outer hole on hub, outer upper on tower
