RE: Installing pushrod guides in Tiger 2 Kit
So i ended up taking one of the cutout scraps from the fuse and drilling two holes in it, threading the guide tubes through the holes, and gluing the wood across the former behind the wing. The servos don't seem to be binding with this setup but I'll check it out to be sure when I get home. Also, should I use the pushrods that came with the kit or are there better inexpensive options? Lastly, I put 90 deg bends on the end, drilled out the middle hole on the servo arm, stuck the bend on and put those little plastic pushrod keepers on the other side. I'm now thinking that a z bend would be much better, but I trimmed the pushrods so short that there's no material left. So, new P-rods or stick with the little plastic keepers?
