RCU Forums - View Single Post - EDF Airliner build thread
Old 03-09-2006 | 05:14 PM
  #40
Splitpin
Default RE: EDF Airliner build thread
Hi MK
No the top strip stays, if I understand your meaning.
We glued 3 strips together, starting from the bottom, a 12mm , a 4mm and a 10mm strip. making a H on it's side stip. The gaps in the H take the two fuse sides slipped in. And this is taped to the fuse inside, both sides. Any 'helping' tape on the outside is now removed. But our 10mm plastic strip showing on the outside covering the join of the 2 fuse halves stays, thats why my pedantic rave on how straight it must be.
Hope that helps and didn't further confuse anyone.
