RCU Forums - View Single Post - Dynamic Braking Question
Old 03-10-2006 | 04:11 AM
Malcolm H's Avatar
Malcolm H
Default Dynamic Braking Question
Could someone using one of the new dynamic braking controllers enlighten me. With my standard ESC I normally set my throttle trim to give and idle prop rather than prop stopped situation. Is this still possible with a dynamic braking ESC?
In otherwords can the ESC sense and maintain a prop idle speed when the motor is being driven by the prop or is the braking a linear function of throttle stick position that is above a certain stick position the motor is driven, below that position it is stopped and gives braking proportional to how far back the stick is moved?
Malcolm
