RE: E-FLIGHT BLADE CP
If you put the super landing gear kit on, all you have to do to replace the main shaft/gear is remove the head, loosen the collar screw, and slide the whole shaft out.... of course some filing is usually necessary on the shear pin hole to get it to slide through the bearing. I can replace the shaft in less than 5 minutes.
