RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-10-2006 | 10:56 AM
  #2495
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: jeffdom1978
I thought the Blade CP has a different main shaft. It is attached to the main gear. The CP2 has the two separate peices for the main shaft like you posted...
maybe they both would work, just doesnt seem like it
They are a little different, but like I mentioned before the CP2 shaft is a 3/8" longer so you need to replace the links with longer ones.
sfinckster- don't you still have to remove the battery tray, too? I'm using the stock tray with the LG, so maybe mine's different. I could replace it if need be by sliding the tray forward, but the CP2 gear is even simpler. Although I haven't bent the shaft since I changed. Wish somebody would come up with a stronger spindle, I keep bending that. And that's a royal pain to pull and straighten.
