ORIGINAL: striderjg
This is y I believe the throttle being switched is a better compromize. U can still control ur airspeed but if ur taking it easy, u can throttle the motor down to save battery life.
I think you would find it touch to throttle the motor if it is on a switch. You can put it on a rotary like the flap and use the computer to mix it. All that I have seen just let it run wide open and use the throttle stick to change prop pitch.
Man, these little electrics have come a long way. Never figured I would want one, and now I have 4.
