RE: My 2300 only likes one prop
To all:
I have folled this thread from the beginning with interest because I have a Midwest Giles 202 with about 120 hours in the building, and have purchased an ST 2300 to power it. I have found the thread helpful. I have now put about a galln and a half in breaking in and setting up the 2300 and have not reached a level of confidence in the way it is running. Basically the same problem as many. So I decided to follow the route of a different carb. Yesterday when going to hobbypeople. net to order a magnum carb I was also looking for a few other supplies that I need at this time. They did not have all I was looking for so I took note of what it would cost for shipping, I then went to tower hobby to get the needed supplies and also checked the price of the 7D OS and found it to be 64.99 and then took note that they had a twenty dollar off for a 125 order, well I had to add a bottle of CA to my order and got this carb and the rest for nearly the same price as ordering the supplies from tower and the mag from Hobbypeople. So if you are considering the carb change you might want to check this out.
