RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-10-2006 | 06:40 PM
  #2504
AJ DRAGON
Default RE: E-FLIGHT BLADE CP
Hi
I was wandering if any one knows if there is a high quality main shaft upgrade available for the HB CP2 because I am really getting sick and tired of replacing the stock stainless steel main shaft that is used on the Blade CP. The guy who thought that a stainless steel main shaft was a good idea needs to have his head smashed in with a rock. IMO the main shaft should be the strongest part on the helicopter not one of the weakest. The balsa wood blades are stronger then the stock main shaft.
