RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 03-10-2006 | 07:31 PM
  #620
walter2323
Default RE: Air Hogs Aero Ace!
ORIGINAL: sxates
The problem with trying to use the AA as a glider is that it weighs practically nothing. Which means that if there is any wind, even movement of air, the plane will be affected (ie, blown away). The other problem is that to turn, you have to have throttle. And since there are no control surfaces, any turning or adjustments you make will add thrust, which will not help it glide. This plane is good for many things, but I don't think glider is one of them.
I've found the best way to get out of a bind (ie, the immediate threat of being blown onto a rooftop or into a tree) is to cut power and glide down and away, applying momentary power to steer as necessary. When you get the elevator trim tabs set up for relatively stable flight (ie, not too much climbing/stalling) it seems to glide alright - best when nose into the wind.
