I am building my first electric airplane and I am stuck. I am currently putting together a Great Planes Mini Super Sportser which was profiled in this month's AMA mag. It uses a speed 400 motor. The manual recomended a Electrifly 8 Cell 9.6 volt 1100 MAh NiMH battery. My hobby store reccomended a Great Planes Electrifly c25 Mini ESC. I am also using a JR 4 channel receiver and transmitter. I am having a hard time setting up the ESC. Is it necessary to install the motor capacitors? It says to solder them on the pos and neg leads and to the motor casing, but the motor leads are not sticking out of the motor. The plane's manual says to strip off the ESC's motor leads and to install the bullet connecters that came with the plane. Also the red and black connecter coming of the battery side of the ESC has a connection that will fit into nothing I have. I assume you wire the motor leads to the motor, the battery leads to the battery(how I don't know) and the the black/red/white wire connecter to the receiver. Am I missing something? Do I have to put a different kind of connecter on the end of the ESC's battery leads that will match up to my battery? Please help... pictures or weblinks would be helpful.
