RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-10-2006 | 10:49 PM
  #2508
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: AJ DRAGON
Hi
I was wandering if any one knows if there is a high quality main shaft upgrade available for the HB CP2 because I am really getting sick and tired of replacing the stock stainless steel main shaft that is used on the Blade CP. The guy who thought that a stainless steel main shaft was a good idea needs to have his head smashed in with a rock. IMO the main shaft should be the strongest part on the helicopter not one of the weakest. The balsa wood blades are stronger then the stock main shaft.
Read post 2487
