RE: engine help
Make certain the HSN is at factory settings.
How is the LSN? If you believe it has fuel when you first try and start it, perhaps the LSN is too lean and the engine is starved after a few seconds.
How about if you start the engine with 1/2 throttle? If you maintain some throttle will it continue to run or stall?
Ryan
