RE: trex tail help needed
If the link is smooth then it is a gyro problem and you must mechanicaly center the tail in nonheading hold to fly straight. If you do not do this then you will fight the chopper for ever. I had the same problem and the fix was the center in h mold was not the same in normal mode.
