RCU Forums - View Single Post - Help! brakes and throttle???
Old 03-11-2006 | 10:25 PM
ehroof
Default RE: Help! brakes and throttle???
sounds like you have to reverse the servo's on the tranmistter, there should be a switch on the transmitter. When you appy throttle it brakes and shuts down, when you apply brakes, the carb should open up if this is the problem.l
