RE: My 2300 only likes one prop
Depending on the diameter of the spraybar, about a 9-10mm bore. Sometimes a restrictive airfilter will help with fuel draw but is only effective at full throttle. Reducing the venturi increases the velocity around the spraybar where it does the most good. Rotating barrel carbs are limited in their ability to draw fuel at part throttle but are easy to make and the most forgiving over a range of applications.
