RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-12-2006 | 09:13 AM
  #2524
djdavidcp's Avatar
djdavidcp
Default RE: E-FLIGHT BLADE CP
ORIGINAL: nyflyer56
Almost forgot, what is the accepted repair for the tail skid?
The stock tail skid is garbage, I replaced mine with a fin from heli-direct.com. I attached it to the tail boom with a 3/16 landing gear mount. Here are links to everything I used:
Here's the tail fin:
http://www.helidirect.com/product_in...roducts_id=751
It's for a HoneyBee Cool or King.
I fastened it on with a Du-bro 3/16 landing gear strap, part number 811. Which fits perfectly around the tail boom. I used a little masking tape inside the landing gear strap to firm up the fit. You can see them here:
http://www2.towerhobbies.com/cgi-bin...&P=WR&I=LXVJ28
I used Du-bro 2-56 Steel Hex nuts part number 560 to fasten it to the boom. Those are the best way I found to mount it. Both are easily available at your local hobby store.
I snapped off two tail supports within about a week of each other. I haven't had a single problem with the tail since putting on my fin and it looks good on the blade. Heres a couple pics:
Doug
ID:	424684   Click image for larger version
