RCU Forums - View Single Post - Range Check
Thread: Range Check
Old 03-12-2006 | 09:35 PM
Jim Finn's Avatar
Jim Finn
Default RE: Range Check
I range check electric powered aircraft this way: (Range checks should be done with the motor running.) Set transmitter on the ground with antenna collapsed. Get motor running slowly and carry the PLANE away from the transmitter the required distance. (50 paces) The reason to do it this way is , the first control to fail is usually the motor speed control and when it does you have control of the plane not the transmitter. Safer this way!
