After re-reading my previous post, it reminded me of a couple of other modifications I have done...
The crank can be modified by bell-mouthing the opening of the inlet passage (the outlet, where the mixture flows into the case )
Another is a "Turbo" cut-out from the above mentioned bell-mouthed inlet blending into the counter weight. If you don't know what this is, check out the link I posted to the Savage .25 engine modificatons.
Another is a radius on the leading edge of the counter weight. Be careful not to remove much material, so you don't throw off the balance. (too much
JB weld in the induction passage just under the carb and blended to a nice radius works well on engines that don't have a ball milled passage.
I did the above mods to the aforementioned Webra .50
