RCU Forums - View Single Post - 50 inch
Thread: 50 inch
Old 03-13-2006 | 12:13 PM
crispyspa's Avatar
crispyspa
Default RE: 50 inch
Terbo,
Not a pusher. The engine is a chainsaw, which runs opposite of a weedy, allowing me to use a normal prop in a pusher configuration. bigger prop selection. It (the engine) was made in 1986.
Cajun,
The only way I can think of to be able to put a muffler on is to move prop away from the engine, which would require machining of a shaft. I think that would be out of the budget. The local machine shop starts a $65 an hour, not including materials. [&o]
18 x 8 ??? Faster top speed ?? Hmmm. but wouldn't that sacrifice low end torque ( for land running)?
Correct me if I'm wrong: Lower pitch prop depends on higher RPM for more speed? This engine has a max rated RPM of 8000.
At only 8000, would a smaller pitch be less efficient?
Also I've tried an APC 18 x 12 , it didn't perform as well as the MAS 18 x 10.(although there was no discernable change in RPM) I think tip width had something to do with that.
