RE: AXI numbering
Definition:
One watt is one joule of energy per second.
1 W = 1 J/s = 1 newton meter per second = 1 kg·m2·s−3
Origin:
The watt is named after James Watt for his contributions to the development of the steam engine, and was adopted by the Second Congress of the British Association for the Advancement of Science in 1889 and by the 11th Conférence Générale des Poids et Mesures in 1960.
MWe, MWt ---
Watt electrical (abbreviation: We) is a term that refers to power produced as electricity. SI prefixes can be used, for example megawatt electrical (MWe) and gigawatt electrical (GWe).
Watt thermal (abbreviation: Wt). This is a term that refers to thermal power produced. SI prefixes can be used, for example megawatt thermal (MWt) and gigawatt thermal (GWt). For example, a nuclear power plant might use a fission reactor to generate heat (thermal output) which creates steam to drive a turbine to generate electricity. See nuclear proliferation for discussion of a reactor that generates 200 MWt (50 MWe), and another reactor that generates 800 MWt (200 MWe).
__________________________________________________ _______________
The joule is a derived unit defined as the work done or energy required, to exert a force of one newton for a distance of one metre, so the same quantity may be referred to as a newton metre or newton-metre (also with meter spelling), with the symbol N·m or N m. It can also be written as kg·m2/s2. However, the newton metre is usually used as a measure of torque, not energy.
As a rough guide, 1 joule is the absolute minimum amount of energy required (on the surface of Earth) to lift a one kilogram object up by a height of 10 centimetres.
One joule is also:
The work required to move an electric charge of one coulomb through an electrical potential difference of one volt; or one coulomb volt, with the symbol C·V.
The work done to produce power of one watt continuously for one second; or one watt second (compare kilowatt-hour), with the symbol W·s
