RCU Forums - View Single Post - OS 40 LA thing
Old 03-13-2006 | 02:29 PM
britbrat
Default RE: OS 40 LA thing
I suspect that the the cyl head screws are loose. That engine has a 4-bolt head with phillips screws -- they often loosen -- it is a chronic problem. I usually carry a supply of socket-head screws in my flight box for student's engines. I can't remember the correct size right off the top of my head.
Make sure that the head is seated flat on the block (not cocked), then tighten the screws incrementally in a criss-cross pattern. It should be OK, but you will have to re-tune the air-bleed screw.
It would be a good thing to also check the back-plate screws & the carb hold-down screws.
